2 members (NJC, baldeagle),
52
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 34 Apprentice | | Apprentice Joined: Sep 2009 Posts: 34 | I searched, found nothing for a panel. Maybe I am a bad searcher ? Mines a 49 and am wondering how the heck it stays in place as well as how it doesn't get ruined in the install process. Just the rear cargo area I am curious about. Thanks !
| | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | What are you looking for as in information? How to properly install. or are you looking for some pictures showing what a correct one looks like?
I think like my burb. There is a retainer ring/Bow. I can have my friend look at his 49 and take a pic or two for you. Jim Carter sales the headliner. He also, has a junk Yard(treasure) and if you are missing a part. He may have it.
PM me or give me a call. Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Sep 2009 Posts: 34 Apprentice | | Apprentice Joined: Sep 2009 Posts: 34 | Mine is pretty complete just rather aged. I will soon be doing some roof repair and it will likely need to be removed. Mostly curious now. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | My 52 is probably different but just as info.... My "headliner" was stuck to the metal roof with what appears to be some sort of black roofing tar. Sounds like yours may be different. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | The panel trucks didnt come with a cardboard headliner in the rear cargo area. They only had it above the driver/pass. area. The suburbans had it all the way back. As Achip says,,there was just some sort of tarpaper,fabric stuff glued to the rear area. | | | | | Joined: Sep 2009 Posts: 34 Apprentice | | Apprentice Joined: Sep 2009 Posts: 34 | Not sure I'll get too carried away with originality. But I do want it to have an oem look. Maybe I'll check out Subs and see how that might look in mine. Or I could go custom being careful not to let it look like a 70's boogie van LOL. Still curious to know how the panel type is installed. Careful slide in place glue as you go ? Thanks for the info so far. Off to search burbs now. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I suspect you guys have a piece of the original PANEL headliner but just in case you ever want to see one I kept a piece of mine ...... just for show and tell. | | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | I have a 56 panel 3800 series and it has the headliner all the way back. Same material as in the front over the drivers area. Is that normal? | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | My headliner is in many pieces but sofar I kept all of it. I will likely buy all new from Carter. | | | | | Joined: Sep 2009 Posts: 34 Apprentice | | Apprentice Joined: Sep 2009 Posts: 34 | Mine "was" complete with a minor tear or two. Now it has many rips and will be torn out as needed. Looks like small rivot like clips (keepers) on each end. Was not wearing my reading glasses  The liner was loose from the roof in the center but held tight @ each end. I've got a replacement roof and can remove a bow to see how its attached. | | |
