| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 10 New Guy | | New Guy Joined: Dec 2009 Posts: 10 | I am doing my very first stovebolt. A 1954 chevy 3100. I need some advice on power windows. The 54's came with vent windows from the factory and I want to replace them with a one piece window. I know that some 48-53 had one piece windows from the factory. Is it possible to put a one piece window in a 54 door? Or do I need to find a older door?
I can't say not knowing.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You can do it in your existing doors. You will have to remove some metal at the back of the vent wing. I tried power windows keeping the vent wings and recommend not trying to use 1980 Buick motors, too much sweep and too powerful. Edit addition: you may need some of the window trim from pre 1950 doors.
| | | | | Joined: Dec 2009 Posts: 10 New Guy | | New Guy Joined: Dec 2009 Posts: 10 | I don't quite follow you on the window trim. Could a guy use a kit from specialty power windows? If I had the $400+ bucks? I never even though that you could graft a window motor from a different car. What car idealy would get the motor from?
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The window channel that the window rides in will need to be longer. I'm not sure what the trim looks like on the earlier doors so that was just a thought of a possible need. For salvage motors, look for something that has a similar inside door contour (nearly flat) like a suburban or truck. The Buick doors I tried were curved and I had a heck of a time getting the motors mounted. I did get it done and had them working but worried that I would roll the window up one day and blow glass all over the place. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The inside door trim for the vent window trucks has a notch cut out and has screws in different places than the earlier ones. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Hagan Street Rods in Nevada offers vent window eliminator kits that have everything needed and aren't expensive.
Evan
