| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | If any one is looking for a welder,lincoln has one on sale for 500.00 Its called an easy-mig 140,uses120 volt input,is set up for gasless flux cored or gas shielded.After going on line and looking into this model,it seems to be really cheap.I'm thinking this would be a good beginners welder for some one like me who has never done it before.What do you boys think.To the moderators,was'nt sure if i should put this in greasy or general topics. Roy | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | this is the right place for tool talk that's the model I've got [CDN tire a few years ago] - excellent machine - get the gas gear .... a bodyman buddy sez he likes it better than the different make he uses all day, and make sure I put him in my will  Bill | | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Thanks for the feedback squeeze.I'm not sure yet if i'm gonna bite the bullet.
Roy | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | This is the welder I have and like it. I have it set up with gas. It is easy to learn to use.
Best of luck
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | As others have said get the gas gear. It's the only way to go for body work. I have two Lincolns, a SP-100 and a SP-170. Both of them are over ten years old and perform nicely. I worked for a sheetmetal outfit and we used Lincoln SP-125s to weld the seams on 4- 5Ft diameter 10 Ga. S/S exhaust stacks that went up 365Ft, plus all the 10 inch 16Ga. S/S lab pipe that fed them. Several miles of weld. The lincolns worked flawlessly. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Yes the Lincolns do the job,at least for a while.But for a few dollars more you can buy a Miller.Big difference is that Miller uses a copper wound transformer,whereas Lincoln uses alluminum. | | |
