4 members (Gray_Ghost, BillCollins, Still At It, 1 invisible), 134 guests, and 2 robots.
Topics128,078
Posts1,056,054
Members48,433
#628738 03/14/2010 5:59 AM
If any one is looking for a welder,lincoln has one on sale for 500.00 Its called an easy-mig 140,uses120 volt input,is set up for gasless flux cored or gas shielded.After going on line and looking into this model,it seems to be really cheap.I'm thinking this would be a good beginners welder for some one like me who has never done it before.What do you boys think.To the moderators,was'nt sure if i should put this in greasy or general topics.
Roy
this is the right place for tool talk
that's the model I've got [CDN tire a few years ago] - excellent machine - get the gas gear .... a bodyman buddy sez he likes it better than the different make he uses all day, and make sure I put him in my will grin
squeeze #628911 03/14/2010 11:45 PM
Thanks for the feedback squeeze.I'm not sure yet if i'm gonna bite the bullet.
Roy
This is the welder I have and like it. I have it set up with gas. It is easy to learn to use.
Best of luck
Dennis
As others have said get the gas gear. It's the only way to go for body work. I have two Lincolns, a SP-100 and a SP-170. Both of them are over ten years old and perform nicely. I worked for a sheetmetal outfit and we used Lincoln SP-125s to weld the seams on 4- 5Ft diameter 10 Ga. S/S exhaust stacks that went up 365Ft, plus all the 10 inch 16Ga. S/S lab pipe that fed them. Several miles of weld. The lincolns worked flawlessly.
KC in NH #629968 03/18/2010 1:56 PM
Yes the Lincolns do the job,at least for a while.But for a few dollars more you can buy a Miller.Big difference is that Miller uses a copper wound transformer,whereas Lincoln uses alluminum.
Moderated by  MNSmith
