| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 23 Apprentice | | Apprentice Joined: Apr 2008 Posts: 23 | I was about a mile from home when I heard an awful noise from my 6cyl in my 61 Apache p/u. The oil light came on and I stopped. A little checking seems to indicate that the timing gears went. Either that or the cam broke. Anyway, it's a six stick. Is it much of as problem to change the timing gears with the engine in the truck? Looks like pulling the radiator will give me plenty of room. Been many years since I had to do something like this so any advice would be helpful. Thanks in advance. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Wow! Sounds familiar... I had a Pinto throw a timing belt years ago. Took the bus, got some tools and parts and changed it on the side of the road. Not fun, but doable. I would think removing the fan and damper should let you get the cover off and check things. I'd be worried about metal bits in the oil... and all through the engine. Might want to at least drop the pan and check for teeth if the gears went. If the cam broke, you may need to tear it down and clean it out.
Good luck!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Did the engine stop on its own, or did you have to turn it off? A sheared cam gear or a cam broken ahead of the distributor gear will stall the engine instantly. If it was making a racket and still running, you've got a broken piston, broken connecting rod, or a rod bearing failure. It would also need to have a major bearing failure to lose enough oil presure to turn the idiot light on, or a broken oil pump drive. Drop the oil pan first, and look for broken stuff! Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The oil pan has to come off, too. There's 2 bolts for the timing cover that go in from inside the pan (I know, crazy isn't it?) You'll be looking at removing the radiator and the grille at least to pull the cam. It's pressed, so a trip to the machine shop may be necessary. This is assuming it's just the gear and not a broken cam.
Bill Burmeister | | |
