| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i need a oil pump pickup tube for my 54 235. i found a couple at a scrap yard but they are pretty nasty looking. i'd rather use a nice clean one in my newly rebuilt motor.
i have not been able to find a new one on the "innertube" or at my local auto parts store.
has anyone found a pickup tube from a different application that works?
has anyone fabricated there own out of a new oil pump pickup tube from a different application? i figured i could dice up a new one and cut some threads on it so it would mount to the pump and its sae threads.
a source for a new '54 oil pickup would work too.;) | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | You could do the oldtime cleanup method we used 50 years ago- - - - -soak the pickup tube in gasoline, set it outside in the dirt, and toss a match at it. All the sludge turns into nice easy-to-remove ash. Remove the pickup screen first, so it doesn't burn away. This procedure also works on sludged-up road draft tubes. Jerry
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | that is a good tip. i have a whole box of parts i'd like to light on fire.
the oil pump pickups i found are bent, dented and protected by a coat of rust. they can be made to work but not without a bunch of elbow grease. | | |
