4 members (Raymond HAYWOOD, Hush, Shaffer's1950, Cosmo), 216 guests, and 4 robots.
Topics128,088
Posts1,055,993
Members48,430
Apprentice
Apprentice
Has anyone installed the power assist steering kit on an A.D. truck from Classic Performance? I'm considering it on my 3800 panel, it's a bolt on with no need to remove any factory components. You even use your old steering gear and column. I'm installing a 250 engine, so finding a power steering pump and brackets at the bone-yard should be no problem.
I've been thinking about it and would like to hear your experience and others when its done.
If it is the ram type like the one used on a 55-57 passenger car (and Fords) they work fine for parking and low speed but are very skittery on the road. It does not give you a good feel in straight ahead driving even with reduced pump pressure. I think the problem is that it reacts too fast for the straight axle geometry. Fred
Are you sure its intended for use on a 1-ton? Things like tie-rod ends are different from what is on a 1/2-ton, and the kit may not work on the bigger truck.
Quote
Diddo. I have a '52 3/4 ton and a '50 1 1/2.....
1948 Dodge 2 ton
1950 GMC 1 1/2 ton
1952 GMC 3/4 ton
The Toyota power steering box conversion sounds like a better system to me. I will be ordering it soon. I have located people who have made the mod and love it. It mounts right where the existing steering box goes with the aid of brackets. My engines a 235 and I'll use the old generater/pump combo to power it.
Keith
