2 members (VicZ, oldsteve),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62786 07/09/2006 6:04 AM | Joined: Feb 2006 Posts: 12 Apprentice | | Apprentice Joined: Feb 2006 Posts: 12 | Has anyone installed the power assist steering kit on an A.D. truck from Classic Performance? I'm considering it on my 3800 panel, it's a bolt on with no need to remove any factory components. You even use your old steering gear and column. I'm installing a 250 engine, so finding a power steering pump and brackets at the bone-yard should be no problem. | | |
#62787 07/09/2006 11:18 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I've been thinking about it and would like to hear your experience and others when its done.
#62788 07/10/2006 1:45 AM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If it is the ram type like the one used on a 55-57 passenger car (and Fords) they work fine for parking and low speed but are very skittery on the road. It does not give you a good feel in straight ahead driving even with reduced pump pressure. I think the problem is that it reacts too fast for the straight axle geometry. Fred
#62789 07/10/2006 2:09 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Are you sure its intended for use on a 1-ton? Things like tie-rod ends are different from what is on a 1/2-ton, and the kit may not work on the bigger truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#62790 07/22/2007 7:38 AM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | Originally posted by NM51: I've been thinking about it and would like to hear your experience and others when its done. Diddo. I have a '52 3/4 ton and a '50 1 1/2.....
1948 Dodge 2 ton 1950 GMC 1 1/2 ton 1952 GMC 3/4 ton
#62791 07/23/2007 7:00 PM | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | The Toyota power steering box conversion sounds like a better system to me. I will be ordering it soon. I have located people who have made the mod and love it. It mounts right where the existing steering box goes with the aid of brackets. My engines a 235 and I'll use the old generater/pump combo to power it.
Keith | | |
