12 members (Hotrod Lincoln, TUTS 59, Gdads51, KEVINSKI, Dusty53, Lonnie, klhansen, Geo55, Gray_Ghost, Otto Skorzeny, 2 invisible), 149 guests, and 3 robots.
Topics128,165
Posts1,056,992
Members48,458
Apprentice
Apprentice
Been searching here and other places and it seems(?) nobody uses tube headers on a 235. I see Cifford makes them and probably others but everybody seems to run Fentons or the like. I am just thinking outloud (or typing LOL)could there be an advantage to tube headers ?,as long as manifold heat was taken care of.
I like the idea of a traditional exhaust note. Dual Smitty's like my dad always talked about. smile
But have to wonder if there is a better way. Like 6 into 1 or 3 into 2 and then into 1.(?)
Seems to me duals(cool as they are) are not really necessary. I'm asking not telling.
Thoughts ?
My guess is it is because the Fentons are so much neater and easier to use.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
If what you want is a "traditional exhaust note" then I'd stick to what's always provided that: Fenton's and Smitty's. I've seen some pretty nice homemade split manifolds here and on other boards that I think would work just as well and sound good too. I haven't heard tube headers but they might work fine too.
I have run nothing but Fentons on my truck. I've always been told that they were more quiet than tube headers, as far as engine noise in the cab is concerned. I suppose it's because they are cast iron like the stock exhaust manifold.
Apprentice
Apprentice
I can see some advantages of the tried and true Fenton cast headers. And will probably go that way, unless tube headers make a big differance. (doubt it, but don't want to assume) So that leads me to pipes size, single or dual ?
I do understand the "sound" factor but if thats the only reason to go duals I'll likely not. And I have no plans for cam swap or head work, just a Landon's 2 bbl.
which I already have.Thanks for your input!
dual for the sound, and about 1 3/4" diameter
