| | | Forums66 Topics128,078 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 49 New Guy | | New Guy Joined: Jul 2009 Posts: 49 | Does anyone know where to purchase new seal track? What I mean is the channel that the interior rubber weatherseal that runs inside the cab around the doors. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The 1947-49 version screw-on type is available only as used. The newer slide in is available in short sections from Jim Carter the technical name is Cab Windlace Retainers oldchevytrucks.com Item #CB350 12" will cost you $16 | | | | | Joined: Apr 2005 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 9 | I have a piece 3 ft long, I also have a rear corner piece about 4-6 inches. send me an email, I will send you a pic if you want. [email protected] $15.00 plus shipping. | | | | | Joined: Jul 2009 Posts: 49 New Guy | | New Guy Joined: Jul 2009 Posts: 49 | Thanks, I had a brillant idea... I own a 1949 Chevy parts truck cab (once the whole truck) so I drilled out the spot welds and removed what I needed. then i welded them on my fixer-upper.
Gary
