2 members (BC59, Bill Hanlon), 152 guests, and 2 robots.
Topics128,088
Posts1,056,109
Members48,434
#626191 03/05/2010 3:55 PM
Does anyone know where to purchase new seal track? What I mean is the channel that the interior rubber weatherseal that runs inside the cab around the doors.
1950 Chevy 3100
with matching trailer
More pix on Photobucket
The 1947-49 version screw-on type is available only as used. The newer slide in is available in short sections from Jim Carter the technical name is Cab Windlace Retainers oldchevytrucks.com Item #CB350 12" will cost you $16
I have a piece 3 ft long, I also have a rear corner piece about 4-6 inches. send me an email, I will send you a pic if you want. [email protected] $15.00 plus shipping.
Thanks, I had a brillant idea... I own a 1949 Chevy parts truck cab (once the whole truck) so I drilled out the spot welds and removed what I needed. then i welded them on my fixer-upper.
Gary
1950 Chevy 3100
Moderated by  ndkid275, Phak1
