3 members (JW51, Peggy M, 1 invisible),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I came across some info on another site on an interesting four link rear installation. The kit was actually designed for a '32 F@&d but worked quite well on the AD. The Kit is available on ebay for $169 + shipping and can be setup to use airbags or coilovers. I might just have to try this!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If you do document the install.
~Jim
| | | | | Joined: Aug 2007 Posts: 3 New Guy | | New Guy Joined: Aug 2007 Posts: 3 | hey i bought a air ride tech. triangulated 4 link to put under my 49' , ran out of room between the bed and rear end ,, went back with leaves (2) and will be putting coil overs on also ,
love many, trust few,alway's paddle your own canoe !!
| | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | Steve- Where did you run out of room under the bed ? I'm thinking of putting a 4 link under my '49
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Jaime (superfly) is doing a build on the HAMB using a similar kit. He may be posting his progress here as well.
| | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | Nope havent Posted the Build Here I shuld post a link.
How do u post a link??? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | to post a link use the buttons on the "Full Reply Screen" or see hereBill | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Nope havent Posted the Build Here I shuld post a link. How do u post a link??? Jaime,i'm sure the guys(and gals) here would be interested in seeing your build with Scotts crossmember as well.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | Ok Here is the Link Superflys Build | | |
