0 members (), 128 guests, and 0 robots.
Topics128,035
Posts1,055,560
#627224 03/09/2010 3:29 AM
I came across some info on another site on an interesting four link rear installation. The kit was actually designed for a '32 F@&d but worked quite well on the AD. The Kit is available on ebay for $169 + shipping and can be setup to use airbags or coilovers. I might just have to try this!
Robert C.
I'm a Genius in the making.
1950 3600
Mobileortho #627282 03/09/2010 5:06 AM
If you do document the install.
~Jim
Mobileortho #627396 03/09/2010 5:09 PM
hey i bought a air ride tech. triangulated 4 link to put under my 49' , ran out of room between the bed and rear end ,, went back with leaves (2) and will be putting coil overs on also ,
love many, trust few,alway's paddle your own canoe !!
Steve- Where did you run out of room under the bed ? I'm thinking of putting a 4 link under my '49
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
nvrdone #627774 03/11/2010 12:51 AM
Jaime (superfly) is doing a build on the HAMB using a similar kit. He may be posting his progress here as well.
Nope havent Posted the Build Here I shuld post a link.
How do u post a link???
Superfly #628215 03/12/2010 7:21 AM
to post a link use the buttons on the "Full Reply Screen"
or see here
Superfly #628221 03/12/2010 8:31 AM
Jaime,i'm sure the guys(and gals) here would be interested in seeing your build with Scotts crossmember as well.
More pix on Flickr.
jockbolter50 #629032 03/15/2010 6:30 AM
Ok Here is the Link
Superflys Build
