4 members (Materman, fonz8261, cmayna, Shardean), 80 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
RAK
Offline
My panel is not lighting up so I am ready to change the bulb ? Everything else works fine.Anything I should know before I unscrew the panel?
the bulbs should be easily popped out by reaching under .... and if changing them doesn't help, it may be the switch [you do know that the dash lights are dimmed by turning the light sw knob?]
J M Offline
If you have no lights at all.It could be the headlight switch. There is a rheostat on the switch to brighten or dim the lights. You just turn the knob to do it. Also check the fuse.
There are several bulbs in the panel for dash lights, and you should be able to get to them from the back side without taking the panel out. If you have no lights at all, you may have a ground issue instead.
Hope this helps.
Jim
RAK
Offline
Thanks guys,I'll get to it this week.
