7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | My panel is not lighting up so I am ready to change the bulb ? Everything else works fine.Anything I should know before I unscrew the panel? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the bulbs should be easily popped out by reaching under .... and if changing them doesn't help, it may be the switch [you do know that the dash lights are dimmed by turning the light sw knob?]
Bill | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | If you have no lights at all.It could be the headlight switch. There is a rheostat on the switch to brighten or dim the lights. You just turn the knob to do it. Also check the fuse. There are several bulbs in the panel for dash lights, and you should be able to get to them from the back side without taking the panel out. If you have no lights at all, you may have a ground issue instead. Hope this helps. Jim | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Thanks guys,I'll get to it this week. | | |
