| | | Forums66 Topics128,283 Posts1,058,512 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Some of the wires leading to my brake light switch are frayed and I want to change them. However it looks like the wires go into the switch and are not attached to the outside. Is this correct? Is there a way of replacing the wires without replacing the switch? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill,
The two wires merely push, just like a bullet connector. There might be a little hair pin clip on each little push-on that helps hold it to the switch.
Look at a picture of the switch in Jim Carter or Chev's catalog and you'll see what it looks like sans wires.
Stuart | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | make shure that you clean the contacts good. Then use electrolit grease. This will keep out moisture. You can use this at all points of contacts. Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
