Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Ridgeback, WICruiser, Joe H), 150 guests, and 7 robots.
Topics128,283
Posts1,058,513
Members48,490
#627155 03/09/2010 12:52 AM
Some of the wires leading to my brake light switch are frayed and I want to change them. However it looks like the wires go into the switch and are not attached to the outside. Is this correct? Is there a way of replacing the wires without replacing the switch?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Bill,
The two wires merely push, just like a bullet connector. There might be a little hair pin clip on each little push-on that helps hold it to the switch.
Look at a picture of the switch in Jim Carter or Chev's catalog and you'll see what it looks like sans wires.
Stuart
Will do Stuart, thanks.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
make shure that you clean the contacts good. Then use electrolit grease. This will keep out moisture. You can use this at all points of contacts.
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
