6 members (Bwana-Jim, J Lucas, Hotrod Lincoln, Jon G, Otto Skorzeny, MikeE), 101 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#625301 03/02/2010 11:51 PM
Need help reinstalling tranny coolerlines. Which lines go where on the tranny to the radiator trans cooler? Its been a year or so since I pulled them out and the manual doesnt sho the positions.
mac
It doesn't make any difference. You are just flowing the fluid thru an enclosed tube within the lower radiator tank. It works the same no matter which way the trans fluid flows.
Chuck
Chuck
Thanks for the reply but after furthing calls to one of the trans companies this is what I found out. The lower fitting on the trans is the high pressure out connector. It goes to the top of the vertical radiator trans cooler. From the bottom connector of the trans cooler the line attaches to the top trans fitting or low pressure side. Hooking up this way the fluid will circulate. If we assumed it was just a loop and the trans pressure line was connected to the bottom of the cooler it would then have to force its way up to the return line against gravity as well and wouldnt flow as efficiently.
Mac
H Online: Content
OK- - - - -since virtually all the trans coolers on the downflow radiators used on stovebolts are across the bottom tank, not vertical, how does your radiator guru handle that one? Also, a lot of the Powerglide coolers were actually mounted to the frame near the bellhousing, with heater hoses routed to them. Your "expert" sounds like he's full of beans!
1 Offline
This is from the 1957 Assembly manual for P/G transmissions.
http://www.55-57chevys.com/coccc/tech/57/302-10.gif
Joe D.
If one side is a "pressure" line and the other is a "return" line then why are both lines the same? I don't think there is any difference and it doesn't matter.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
