2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
1 Offline
I am in need of a windshield frame for a 37 pickup. Are there other years that will interchange?
Dale
Should be same as 36-38 and I'm sure there are repros out there. I'd contact Jim Carters or Chevs of the 40s websites.
1946 1/2-Ton Chevy
1936 low cab is shorter by an inch. Here is an address for reproductions. http://www.WindShieldFrames.com . I priced a 1936 low cab and it came in at $450 for raw steel.
Good luck.....
Finding a good, rust free frame will be tough. Likely need to go with a repro. Make sure you order rubber seals from Steele Rubber Products - much better quality / easier to work with than other stuff out there.
1940 Chevy KC 1/2-Ton
The 37 and 38 are the same. The 36 will not fit even though it looks like it will. Another choice is a GMC windshield from a 37-38 GMC. They were chrome plated from the factory. Reproductions are available.
