8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 4 New Guy | | New Guy Joined: Feb 2010 Posts: 4 | I am in need of a windshield frame for a 37 pickup. Are there other years that will interchange? Thanks Dale | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Should be same as 36-38 and I'm sure there are repros out there. I'd contact Jim Carters or Chevs of the 40s websites. | | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | 1936 low cab is shorter by an inch. Here is an address for reproductions. http://www.WindShieldFrames.com . I priced a 1936 low cab and it came in at $450 for raw steel. Good luck..... | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Finding a good, rust free frame will be tough. Likely need to go with a repro. Make sure you order rubber seals from Steele Rubber Products - much better quality / easier to work with than other stuff out there. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The 37 and 38 are the same. The 36 will not fit even though it looks like it will. Another choice is a GMC windshield from a 37-38 GMC. They were chrome plated from the factory. Reproductions are available.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
