Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall), 54 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#626643 03/07/2010 4:52 AM
I need to replace my rear shocks on my 58 1/2 ton. The originals have pins that are part of the shock. Do they make these anymore? What would you recommend to stay close to original?
model70 #626646 03/07/2010 5:03 AM
Not sure what you mean by "pins". On the rear, the mounting studs are part of the frame on the '55-'59s. The fronts, however, do require kit #AK32 (Monroe) to mount them on '58/'59.
Bill Burmeister
LONGBOX55 #626649 03/07/2010 5:13 AM
Sorry, by pins I mean eyelet bolts. Talks about this in the service manual as well.
model70 #626653 03/07/2010 5:40 AM
Just from what I read in the manual, the '58 is the same as '55. The mounting stus should be part of the frame/axle on 1/2 ton. There's a possability that the shocks have been replaced in the past, and original studs replaced with aftermarket mounting bolts similar to what you describe. I have run into this on later model vehicles with aftermarket shocks. You may need to use an aftermarket mounting kit, such as AK32 to fit the shock to the truck.
Bill Burmeister
LONGBOX55 #626654 03/07/2010 5:45 AM
A quick search of the Monroe site turned up Sensatrac #37188 for a '58 1/2 ton rear. The picture shows new studs, bolts, bushings, looks like everything you'd need. You'll probably have to have a Monroe dealer (like NAPA) order them for you but should only take a couple of days.
LONGBOX55 #626655 03/07/2010 5:46 AM
Thanks Bill. I'll try to look it up.
model70 #626656 03/07/2010 5:48 AM
Thanks again for the information. This is an amazing place to spend some time.
model70 #626657 03/07/2010 5:50 AM
Advance Auto and Sears are also Monroe dealers if you don't have a Napa close by.
Bill Burmeister
LONGBOX55 #626783 03/07/2010 10:31 PM
Call and give the number for cross reference to auto zone and they have gabriels.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
