1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | I need to replace my rear shocks on my 58 1/2 ton. The originals have pins that are part of the shock. Do they make these anymore? What would you recommend to stay close to original? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not sure what you mean by "pins". On the rear, the mounting studs are part of the frame on the '55-'59s. The fronts, however, do require kit #AK32 (Monroe) to mount them on '58/'59.
Bill Burmeister | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Sorry, by pins I mean eyelet bolts. Talks about this in the service manual as well. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just from what I read in the manual, the '58 is the same as '55. The mounting stus should be part of the frame/axle on 1/2 ton. There's a possability that the shocks have been replaced in the past, and original studs replaced with aftermarket mounting bolts similar to what you describe. I have run into this on later model vehicles with aftermarket shocks. You may need to use an aftermarket mounting kit, such as AK32 to fit the shock to the truck.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | A quick search of the Monroe site turned up Sensatrac #37188 for a '58 1/2 ton rear. The picture shows new studs, bolts, bushings, looks like everything you'd need. You'll probably have to have a Monroe dealer (like NAPA) order them for you but should only take a couple of days. | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Thanks Bill. I'll try to look it up. | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Thanks again for the information. This is an amazing place to spend some time. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Advance Auto and Sears are also Monroe dealers if you don't have a Napa close by.
Bill Burmeister | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Call and give the number for cross reference to auto zone and they have gabriels.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
