| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | I am installing a 700r4 in my 61 longbox. I was thinking of going to a one piece driveshaft and ditching the carrier bearing. The main reason is cost. I think I can get a driveshaft out of a suburban and modify it. The trans is 8 to 10 inches longer than the stock. Can I get away with this or is it going to give me trouble? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It still has to go through that crossmember doesn't it? Not sure it's big enough to allow a full range of motion without a carrier there, Scott | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | There are maximum lengths you can have a single drive shaft. The best is to consult a reputable driveshaft shop as for the maximum length you can go with your driveshaft at the rpm you expect to run at. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Drive shaft performance varies with length, diameter, tubing thickness and tubing material.
The longer the drive shaft the larger around it needs to be in order to work smoothly at a given speed.
I'm sure you can make a drive shaft long enough to do the job but in doing so may be limiting your top comfortable speed because of drive shaft vibration. And if the drive shaft is vibrating you'll loose bearings and seals and u-joints.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | There are maximum lengths you can have a single drive shaft. The best is to consult a reputable driveshaft shop as for the maximum length you can go with your driveshaft at the rpm you expect to run at. I agree! If you're curious what all goes into designing and installing a driveshaft check out these manuals http://www.stovebolt.com/techtips/driveline/setup/index.htmlGrigg | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | There are maximum lengths you can have a single drive shaft. The best is to consult a reputable driveshaft shop as for the maximum length you can go with your driveshaft at the rpm you expect to run at. Less than 5 feet seems to be the magic number, or at least it was on my 1959 GMC longbed. I believe I am running a 4 inch tube. The shop that initially made my driveshaft didn't do a best job as I had a bad vibration at 3000 RPM. I ended up having that driveshaft made 3 times. The third time was because it dropped when the rebuilt rear end failed. | | | | | Joined: Nov 2009 Posts: 29 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 29 | One thing you might want to check out is Chevy Vans. I had a 1991 Chevy Van with the short wheelbase, and a 700r4 tranny. It had a fairly long 1 piece drive shaft, and IIRC it was also made of aluminum. I think that would be your best bet since it is lightweight, and is made for the 700r4.
-Nick
1995 BMW 318i 1988 Chevy Silverado 4x4 1967 Camaro 1950 Chevy 3100 pickup
| | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Thanks for the tips guys. The trans is actually out of a early 90s chavy van. there is a decent amount of room for the shaft to move but I won't know for sure intil I get everything bolted in. | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I had a trans guide with dimensions earmarked, but I can't find it. This is a guess, but isn't a 3spd column shift trans with bell about 2 1/2" shorter than a 700R4. In another thread you said you had to make side mounts for the engine and was planning on moving it forward. The 3spd and the 700R4 both use a 27 spline slip yoke. Find a truck like yours with a 3 spd and see if the front half of the drive shaft will bolt up.
'67 GMC 3/4 292 4spd
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I used to go to Jeep Surplus in Lexington Kentucky when I lived there. They had a drive shaft mounted on the wall off of a large truck someone made one piece. It was sort of pretzel shaped. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | My other concern besides cost was that my original driveshaft has the slipyolk between the carrier bearing and the rearend while my 700 has it in the trans which means I would have two which I believe is one to many. I only moved the engine forward about an inch. | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | It will be about 6 feet long. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | 6' is getting pretty long. Below is the recommended tube thickness at various lengths. I would would strongly recommend 2 drive shafts however, if you have a slip joint at the transmission, it is a problem. You really should have a U joint at the back of the transmission and a slip joint between the center bearing and the third member. If you go the 1 piece route, I would certainly put a guard around the drive shaft. A 6 ft drive shaft can really be wicked. The general length limitations are as follows: * Installed length u-joint center to u-joint center. ACS = Adjusted Critical Speed Suggested factors for Adjusted Critical Speed: Safety Factor = 0.75 Correction Factor Outboard Slip = 0.92 Inboard Slip = 0.75
TC = Theoretical Critical CF = Correction Factor SF = Safety Factor Tube O.D. Maximum Length * 3.0 in. 60 in. 3.5 in. 65 in. 4.0 in. 70 in. 4.2 in. 72 in. 4.3 in. 73 in. 4.5 in. 75 in. 5.0 in. 80 in
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I had a 63 C20 lwb with a TH400, and a single piece drive shaft. The previous owner had replaced the 292, 3spd, with a 350 olds. I still have the drive shaft.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
