12 members (HandyAndy, Southerntruck, Gdads51, Peggy M, 3B, Oswald, 1955 1 Series, Jon G, Otto Skorzeny, Gray_Ghost, 2 invisible), 165 guests, and 2 robots.
Topics128,103
Posts1,056,183
Members48,436
Which five speed Overdrive manual trans do I want in order to get decent freeway speed from my 57 3600?
Towns in Nevada are far apart, 55 MPH will not cut it.
Engine is a strong 350.
Still want to haul and tow, may want to keep a granny low if possible.
But I have to get a taller final drive.
Prefer not to change the rear axle, trans seems like it may be easier and less expensive.
I will replace the mechanical trans brake with a line-lok.
Current trans works and shifts very well, just too low in fourth gear.
1957 Chevy 3600
At these prices I want my gas 100 octane, leaded, and my windshield washed!
1994-1997 dodge 2wd NV4500. 5 speed with granny low and OD. 5.61:1 granny, 0.73:1 OD. This transmission is easily adaptable to work with the stock clutch linkage and a mechanical speedometer, and is strong enough to take anything you can throw at it. 5th gear would affectively give you a final drive of 3.34:1 instead of 4.57:1. I am not sure of what size tires you are running, but if they are about 31 inches in diameter, RPM at 70mph would be about 2530 rpm
What bell housing?
Mounting kit available, or have to fab my own?
Had not expected a Dodge trans to be the answer.
1957 Chevy 3600
Standard chevy bellhousing with a 1 inch thick adapter. Do a search on this site for the NV4500, there is lots of info on the swap. If you are still confused... pm me. I put one of these in my 1959 gmc 1/2 ton longbed behind a well built pontiac v8. this swap will move the shifter back 6 inches compared with the stock 4 speed. The GMC v8 sits about 4 inches forward of where the chevy v8 sits, so check to see if you have clearance with your seat.
http://www.offroaders.com/directory/products/NV4500.htm
Info on Chevy NV4500 near the bottom of the page.
'67 GMC 3/4 292 4spd
