1 members (NJC), 62 guests, and 1 robot.
Topics128,089
Posts1,056,004
Members48,430
#62526 07/04/2006 6:43 PM
Junior Member
Junior Member
Got a 230 6cyl. Oil light not going off after cranking. Oil pump is just a few years old. OK.. Follow my logic(more likely my lack thereof) If I put a new oil Filter on (dry, w/out pouring any oil into it first) then crank the motor and let it run for 15-20 seconds, then kill motor and remove brand new filter. My question is then, if the filter is full of oil does that mean the oil pump is working. Is that evidence enough?
Ex Hall Monitor
Ex Hall Monitor
Pumping oil and pumping the correct volume at the correct pressure are different things. You could fill the filter and still burn up your engine. Take the time to test it correctly. Use a known good gauge to check the pressure. To paraphrase the old Fram commercial: Pay me a little now or risk paying me a lot later.
Junior Member
Junior Member
Thanks Tiny, What pressure reading would indicate that it is operating in the correct range?
#62529 07/04/2006 11:03 PM
Ex Hall Monitor
Ex Hall Monitor
Not sure on the 230 & with the holiday this is a bad time for a quick answer. There are lots of folks here with your engine that will be able to help with specifics but they may not check the forum until tomorrow sometime. One of the best things you can do is to purchase a manual for your truck. eBay is a good source for manual reprints. Good luck.
#62530 07/05/2006 12:41 AM
The 230 in my '63 runs at about 30 psi at idle and jumps up to 40 on the highway at ~ 2500 rpm. Not sure if that's normal, but it hasn't locked up yet from insufficient oil flow.
Daily Driver 63 C-10 LWB Fleetside
Time to check your low pressure sensor. Sounds like you problem may not be with the oil but will the indicator/light.
I would just change the sending unit, they're cheap and not worth a lot of testing and messin' around.
Or, install a gauge directly into the port temporarily to see what you have.
Junior Member
Junior Member
Thanks everyone for the help! I installed an inexpensive oil pressure guage Saturday, fired her up, and got a pressure reading of about 25-30 at idle and 35-40 on the move. Sounds like it wasn't the oil pump. Thanks again for the help. It's a 1965 Chevy fltside/swb .My grandfather bought it from the original owner in 1968. I got it when he passed away recently. The motor sounds good(230), but the body is rough, not bad rusty, but every panel has at least one dent.I plan to restore it to as original as practical.I hope to do do all the work myself. The mechanical part doesn't worry me ,I can usually work my way through mech. problems. The body is a different story! Wish me luck. I plan to rely on this site heavily!
Ex Hall Monitor
Ex Hall Monitor
I'm happy we could help. Good luck on your restoration.
