1 members (Otto Skorzeny),
90
Mod | | | Forums66 Topics128,090 Posts1,056,380 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68504 11/13/2006 4:01 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I seem to remember someone mentioning replacing the mesh from their "Regular and Flame Arrestor" air cleaners with a modern paper filter. The mesh measures 1 1/2" x 6"od,4 1/2"id, anybody know what numbers will fit the bill? Fram/AC etc., or model of auto that would use one this size? Denny Graham Sandwich, IL
Denny G Sandwich, IL
#68505 11/13/2006 11:11 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Denny,
I took my mesh filter to the local Napa and spent 1/2 hour comparing until I found the one that would work....If memory serves me...the one I found was out of a mid to late 80's GM car... | | |
#68506 11/14/2006 12:20 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Wish my NAPA dealer was that hungry, around here thay couldn't care less if you never walked thru the door again. Sure wish I could get a number. If ya remember or happen to take a look at the number on the filter, I'd appreciate it if you could post it. Thanks, Denny Graham Sandwich, IL
#68507 11/14/2006 2:41 AM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | NAPA # is 2373, lists the size as:
I.D.(Inches):4.679 O.D.(Inches):6.07 Height(Inches):1.95
Fram # CA77
Carquest # CFI87373
I went with CarQuest because the top and bottom is black, Fram is Orange, not sure what color NAPA is.
-Tom
1950 Chevy 3100 w/ 1956 235
#68508 11/14/2006 3:30 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Denny, What you want is a Fram CA77. It fits perfect and with the perferated mesh around it looks original.
Glenn, | | |
#68509 11/14/2006 6:14 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks guys, ya come thru in this one. I'm printin out the numbers right now and will take a look in the morning. Denny Graham Sandwich, IL
#68510 11/29/2006 12:41 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ok, I picked up a paper element from Carquest, # CFI-87373. It’s black and has a wire screen outside and looks pretty original, at lest to the untrained eye. Now, I have a little more to say about using this element. The ID is a little to large and allows it to move around some and not center up properly. The ID measures 1.625" and the original screen is 4.5". The biggest problem with it’s 1.9" tall, where the original screen is 1.375", the .5”+ means the stud is even with the top cover or just a hair below. To cope with the stud, yet leave everything original, (remember, first do no harm), I made an extension that brings a new #10-32 stud above the cover. This is even difficult because of the old stud being even with the top cover. When you turn the new threaded portion and drill and tap the internal thread, the two meet at the top cover. It would have been better if the old stud were a little shorter. To cope with this I’m putting a rubber gasket below the element to space it up another .125”, making it a full 5/8” taller than the original. The extra height is a little more noticeable and looks, at least to me, a little out of proportion, but all in all it looks pretty good and will work fine. I've placed some pictures into Webshots that better explains it. http://rides.webshots.com/photo/2615797910098611668VxBFZI I would like to know what the number of the element is, that the vendors are selling, Jim Carter (ME2381 @ $7.50) in particular comes to mind. And how well they fit the housing. Denny Graham Sandwich, IL ps. Oh, by the way, Carquest says this part number listing is for a "John Deere, Kohler or Wheelhorse".
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Let me revise those dimentions, CFI-87373 is 6 1/16"x 4 5/8"x 1 7/8". The original is 6"x 4 1/2"x 1 1/2". DG
