7 members (WICruiser, 55shaker, Gdads51, Hotrod Lincoln, greenie-reddy, TUTS 59, 1 invisible),
144
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,379 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 478 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 478 | FOR YOU GUYS WITH BIG TRUCKS AND 7'TALL GARAGE DOORS. I GOT THE IDEA OF GETTING USED FORK LIFT TIRES (THEY WERE FREE) MAKING PLATES WITH HOLE PATTERNS AND WELDING THEM IN. I HAVE EVEN DROVE THE TRUCK AROUND THE BLOCK ON THEM {ONE TIME}THE ONLY PAIN IS CHANGING THE WHEELS BACK AND FORTH. SEE PIC IN DITY GALLERY.
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Ok, Chris we have to see pictures of this.. MONGO | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | I'm with Mongo Chris, havin' a hard time with a visual on this setup. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... I've let the air out of van tires before to get one in the shop but this one is new to me.....yep, that is definitely a Kodak moment... Pics please!!  | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Is that what you call a COE LOW Rider?  | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | I haven't been able to view anything but the one picture in (Snapfish) in the DITY post. Has anyone else had better luck? What's the key to getting in without signing up?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I copied it over to my Picassa which I don't think you need a password to get in. All I found was one photo of a forklift rim mounted to the steering axle which isn't a bad idea. In fact the whole project looks good. http://picasaweb.google.com/crenwelgeoil/Desktop?authkey=Gv1sRgCOianpPV962_Hw#5443445292205427154 I think you have to be a member of Snapfish to get in. I get into things like that with a Yahoo address that I never check.
| | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | We used to have a small shop and had to work on combines while the big shop was being built. Someone welded the wheel center for a combine in a truck rim. They would swap the tires and drive the combine right in. Swapping the tires was a pain but it beat working outside in the winter.
Before you weld on any rims, be sure to watch Bridgestone's video on pyrolisis. You can find it on youtube. | | | | | Joined: Apr 2008 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 19 | Here in Jackson is where they make Teragators and Rogators and that's how they move the big floaters around the plant. Just old shabby tires mounted on rims with the right hub configuration.
When the Work Day's Thru...This Bud's for You!!!!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They load the "monster trucks" on trailers to haul them with just little tires on them too.
Grigg | | |
