0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I think i know the answer to my question,but want to be sure.Are the suburban and pickup rear view mirrors the same (1947-1953)? My suburbans mirror looks totally different than my pickups mirror.I know the truck has the correct mirror.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2010 Posts: 29 New Guy | | New Guy Joined: Feb 2010 Posts: 29 | Tim, I believe that you are correct that they should be the same mirrors. If not we will both learn something today. Also I had a question for you. I was looking at your Photobucket picks on the heater refurb and noticed the decal on the defrost cable bracket. The one that says defrost. How do I get one of those.
Thanks! Justin
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | On the drivers side there are at least two different mirror arms. There is one that turns upward and makes the mirror the same approximate height as the passenger side mirror. I don't know what it came off of because I picked it up at the swap meet in Denver. It could be a Suburban difference or it could be a year difference. I am fairly certain that all my arms are OEM and not repros. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | friedgreentmater,I'm talking about the rear view mirror that is between the two windshields . Canopy man,I purchased the decals at jim carters,here is a link. heater decals 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | DOH! I don't even have an interior mirror. Can't seem to find one. | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | My 1941 1 Ton PU had no rear view mirror just side view mounted on the upper door hinges.
My 1946 1/2 PU had one mounted on the center windshield division bar. It was a pain because whenever you opened or closed the wind shield you had to readjust the mirror.
My 1946 Suburban had the mirror mounted to the bottom of the over head panel.
Take your pick, if no holes were drilled in your overhead panel you either did not have one OR it clamped to the division bar. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Here's the deal,i know where the mirror installs,on the center division bar for 1947-1953 truck,panel,suburban.It is screwed to the division bar with one screw not clamped. I took a closer look at the mirror and bracket,even took some pictures.I think the mirror is out of an art deco style truck.You tell me what it's out of,here are some pictures. rear view mirror ? rear view mirror ?? The original question is are the truck and suburban rear view mirrors the same ? Yes or no ?? Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I would think, Yes, Tim. I know they were the same in 54/55. And, I doubt very much that GM would make different standard mirrors in the same year.
Over the years, I have seen many styles of non-prismatic mirrors in 48-54 trucks. When I needed replacement mirrors in the 60s-70s, I'd go to junk yards and look for anything that fit.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My March 1954 Master Parts Catalog lists no interior mirror prior to 1947, one interior mirror for '47-50 (986632), one for '53 (986651), and one for '54 (986948). There is no interior mirror listed for '51-'52.
For the record, outside mirrors are as follows. '31-54 ALL outside (5-1/16 OD) mirror only 3696632 '39-50 ALL outside, less bracket and arm, black (6-3/16 OD) 602073 '47-53 ALL outside, mirror (5-1/32 OD) w/adj. arm (extendable 8-7/8) 986440 '54 All outside, mirror (5-9/16 X 7½) w/adj. arm and atach. parts (extendable 8) 986985 '54 ALL outside, mirror (5-9/16 X 7½) 986986
This info is from the commercial section. It does not include car applications. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Cletis,thanks for the information.This is strange that 1951&1952 didn't show a listing for the rear view mirror.I will install a rear view mirror like my pickup has,one that bolts to the division bar.
