Brrrr
place holder
2 members (G508, Hush), 128 guests, and 3 robots.
Topics128,271
Posts1,058,414
Members48,485
#623235 02/25/2010 1:05 AM
I'm blasting some pretty rusty parts. I'm using 80 grit glass beads. It's doing a pretty good job, but I'm wondering if anyone has any ideas for anything else that might do a better job a little quicker.
The best things in life are FREE!
it's called black magic it's the best i've used so far
Pete
..... I have used several kinds in my cabinet. I usually keep a bag of glass beads, a bucket of plastic media, and some fine and medium sand.
For "most" of what I do I use the fine sand. It does a good job on my stuff and its cheap. A 50 lb bag is $3.28.
I buy mine and it is actually blasting sand from a local concrete mixing place. Its all sized and flows good in my system. I have a bag of the Black Beauty Pete mentioned from tractor supply but it cost almost $9 a bag...but I only use it on really bad rusty stuff.
Hope this helps.
I would not use the real corse stuff I have a scat blast cabinet and the corse stuff will eat up your gun real quick like.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
For years I've been using white silica sand which does a better job on rust than brown sand.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Glass bead is not for rust removal Jimmy, it is usually used for shot blasting, peening, honing, cleaning and light deburring it and it leaves the surface with a nice even color. We used to bead blast connecting rods when reconditioning them, which made them look like a new forging and served to relieve minor surface stresses. When working as a high vacuum technician I used glass bead to prepare the insides of vacuum apparatus.
To effectively remove paint or rust you need something more aggressive, i.e., an angular grit blast media. The best media would be Silicon Carbide; it’s hard, lasts a long time and is very aggressive, to a commercial user this saves a lot of time, which translates into money. Next step down the ladder is Aluminum Oxide, it is an excellent blast media, sharp and long lived but like Silicon Carbide is more expensive than sand or ash and is typically used in a closed cabinet.
A little more expensive than sand but much cheaper that Silicon Carbide or Aluminum Oxide is Amorphous Glassy Coal Slag, aka Black Magic®, generally very aggressive but breaks down fast, commonly available in several grades, not hazardous to your health.
The most common blast media for open blasting is sand, and of course where the generic name “sandblasting” was drawn from. Some sand is better than others and this has been discussed often here and on many other forums. Playground sand for instance is usually beach sand, which is smooth from being tumbled by the waves so the edges are not sharp. It will work but is not very aggressive, fractures easily and can only be recycled a couple of times before it is turned to dust. Silica sand is very good as a blast media but it has serious health issues when it becomes air born, i.e., silicosis. Common sand that is used for concrete mix is about the cheapest way to go and will probably give you the best bang for your buck if your open blasting out behind the barn.
At the bottom of my list is Soda. Removes paint, not very aggressive useless against rust.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
THANKS for the tips. I purchased some aluminum oxide... so much beter. It's like night and day
