3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#619835 02/14/2010 5:49 PM
I want to build a stand to put my cab on so I can work on it and have it off of the frame so I can work on it. Does anyone have any ideas on this?
Doug5558 #619842 02/14/2010 6:19 PM
In the tech tips section- http://www.stovebolt.com/techtips/ under general bodywork there are 3 writeups on just how to do what you want.
Chuck
Hookalatch #619856 02/14/2010 6:53 PM
I KNEW I'd seen one somewhere before! There's just so much information on here and other sites I couldn't remember where I'd seen it! Thanks!
Doug5558 #619895 02/14/2010 8:40 PM
I'f you don't need to move it......http://img230.imageshack.us/img230/6200/82509032.jpg
gmbs #620392 02/16/2010 3:16 AM
Just a note - if you're going to be doing work such as replacing body panels, leaving it on the frame is best, as you can make sure things line up correctly. It's easier to adjust when it's on the frame before you weld, as opposed to welding off the frame and then trying to make adjustments once you put it back on the frame. If you're not doing any panel replacement then it doesn't matter.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
gmbs #620396 02/16/2010 3:30 AM
V
V Offline
vickraft #620902 02/17/2010 7:14 PM
i went to a boat storage place and picked up a jet ski trailer for 75.00 and put a wood bed on it and it works great. i can easily move the cab around in my garage and i use it to take it to the body shop. Paul
wodniw5 #621008 02/18/2010 12:42 AM
Never thought of that. I think I'll see what I can find around here.
Samantha #621299 02/19/2010 1:39 AM
I want to paint the frame before hand though I suppose it could wait. Plus, I have the 55 cab on the frame and the 58 cab sitting in the floor. I intend to use both cabs to make one. I guess I could remove the pieces I need then place the 58 cab on the frame.
vickraft #621300 02/19/2010 1:50 AM
I like the rotating cab stand.
Doug5558 #621415 02/19/2010 7:21 AM
"MONGO"
"MONGO"
I've thought about building a rotating stand similar to this for some time. Great pictures it looks like a good design. How hard was it to rotate the cab with it in place?
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
KCMongo #622053 02/21/2010 5:40 AM
"MONGO"
"MONGO"
Another good rotating stand that I was impressed with that would be mighty handy is one built by kiwiwilly for his COE cab.
A couple pics Here and Here.
Be great to design one that would work both ways and rotate on both axis'.
Mongo
Mongo's Garage
KCMongo #623083 02/24/2010 5:14 PM
how heavy is a raw cab?(47-53)i'm thinking of building some heavy duty sawhorse style stands out of lumber?
tyler h #623085 02/24/2010 5:31 PM
Incorporating appliance casters into a cab stand sure helped me with maneuverability. I used an old futon frame but something can be made out of a couple pallets in a pinch. IMO it takes 4 guys to lift it safely.
You Tube
Curt B. #623099 02/24/2010 6:27 PM
I've tried with two people and you have to plan a spot for the cab to land when you drop it! Actually, two can do it but only for short distances.
