| | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | engine 1980 350 (5.7L) with 883 heads, roller rockers and crane 100052 (272 degree) cam. Not sure of the bore, but the engine has been rebuilt. The carb is an Edelbrock 1405 and the problem is it seems to be running a little bit too rich and I have developed a leak at the secondary shaft on the passenger side. I do not have a fuel pressure regulator and my fuel pressure gauge is broken and does not work, but before it broke it was showing about 7 psi. If not for the leak I would have no complaint. I do want to find a good Carter Quadrajet and replace it but the dollar is a bit short at this time. Does anyone have any ideas for fixes to check out? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 7 lbs. is too much for an Edelbrock AFB type carb. It should be 4-5. If gas runs out the shaft it is flooding. Although I prefer the Q-jet the Edel. is a good carb. Also a lot depends on the manifold. The Carter is a squarbore & the Q-jet is a speadbore. Most basic performance aftermarket manifolds are set up for both. Some manifolds need an adapter to change between the 2 different type carbs. Q-jets are Rochester carbs. although Carter built some of them for them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | That is kinda what I suspected. I will install one of the pressure regulators that I have laying around. I already have the intake for the AFB set aside, just waiting for the cash to get a carb. Inspection of the heads I took off last weekend indicates the nice brown color on the valves so I think it only floods while at idle or decelerating. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't understand. The edelbrock carb. is basically the same as an Carter AFB. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | maybe in form and function but not what I want my engine to look like. I am looking for an old quadrajet, late 60's or early 70's. When they are right they are great carbs. and I can get a decent air cleaner without all that high-rise junk on my engine. | | |
