2 members (Thomaslb, Eddie54),
166
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62276 06/27/2006 2:32 PM | Joined: Sep 2004 Posts: 19 New Guy | | New Guy Joined: Sep 2004 Posts: 19 | Does anyone know what parts I can use to convert the single system on my original 1940 1/2 ton to a dual master cylinder with or without a power booster. I have seen all kinds of posts in the archives on later models but none on 1940. The only thing I want to change on my original truck is the brakes. I just don't feel comfortable with the single system. Thanks | | |
#62277 06/27/2006 4:04 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'm sure your 40 is simmilar to my 46 so you can use a master cylinder from a 69 mustang (drums front & rear), fab up a bracket that will bolt to the original holes in your pedal assembly and replumb your break lines. It's a little bit of work but if I can do it. It can't be that hard. You'll want to make sure that your brake shoes are good and that your brake cilinders are in good condition also. If you want some pictures of what I did contact me directly and I can e-mail them to you. (Sorry I can't post them here) George | | |
#62278 06/29/2006 4:47 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dale, ONE of the catalog folks offer a dual mastercyl but I forgot which one. Check the on line catalogs for master cyl and see which one it is. I believe it was Filling Station but may have also been JCarter or Chevs of Forties....it was one of the three. I know they listed one for a 37 1/2 ton but believe others as well. Good luck. | | |
