2 members (Peggy M, Simso),
291
9
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62151 06/25/2006 12:16 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Anybody have the short version of how to tell the difference between small block chevy engines? 400 vs 350 vs 327 vs 305? I have located a '79 truck that I'm going strip next weekend that is supposed to have a 350 in it and I want to verify that it is indeed a 350 before I go to all the trouble to pull it out of the truck and start the rebuild process. Since the guy I'm getting the truck from is family I would normally trust what he said was in the truck, but this one was picked up at an auction after some kid rolled it so he hasn't driven it or turned any wrenches on it and is only going by the information that was available when he bought it. I don't expect that it will have "This is a 350" emblazoned on the valve covers. | | |
#62152 06/25/2006 1:45 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#62153 06/25/2006 10:42 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | | | |
#62154 06/26/2006 4:27 PM | | Anonymous Unregistered | | Anonymous Unregistered | Visually there is no way to determine if you are looking at a 305, 307, 327, or 350. The only sure way is to get the engine code/suffix that is stamped on the land area just forward of the right hand (passenger) cylinder bank. The links provided by the others here are decoders which will tell you what size the engine block "should" be.
One method to tell if you are looking at a 2 bolt or 4 bolt engine without dropping the oil pan is to see if there is a small pipe plug on the block behind the water pump. If the plug is there you more than likely have a 4 bolt block. | | |
#62155 07/01/2006 2:56 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | | | |
#62156 07/01/2006 10:47 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Originally posted by panel boy: IF the '79' has it's original motor;the 350 in trucks will have an 8 inch harmonic balancer. the 400 has 3 freeze plugs in the side of the block while all other small blocks have two. you can also look up the casting number at the back. The freeze plug thing is not a hard and fast rule. There are some exceptions...although I can't remember them off the top of my head. It's true in most cases, tho. However, the dead giveaway (or good news, depending on how you look at it) is the asymmetrical harmonic balancer on the 400. They're externally balanced motors so the balancer and flexplate/flywheel have the balancing weights rather than the crankshaft. | | |
#62157 07/01/2006 10:34 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Usually the number right behind the distributor,drivers side,if the last 3 numbers are 010,it's a 350. | | |
#62158 07/03/2006 8:30 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Well, my original assumption was incorrect...there was a sticker on both valve covers that said "Target Master 350 - General Motors Parts Division". Now I have another question...is this an aftermarket "crate motor" from GM or was this the original motor that came in a '79 Silverado? I looked up the casting number using the handy information above and it checks out as a 77 - 79 350 with either 2 or 4 bolt mains, but the stickers on the valve covers are sort of curious. | | |
#62159 07/04/2006 7:51 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well I have a couple sets of those same valve covers and I can imagine being happy to swap them straight up for some other designs.
So maybe smeone wanted whatever used to be on this motor and traded?
Or someone put these valve covers on to sell the motor as a Target Master?
I've no idea what casting numbers are common on Target Master motors. Anyone know?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
