0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62072 06/23/2006 9:37 PM | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | In an earlier post I mentioned some 3.38's for my 55 truck.You Bolters were right, where do you find them, I've been calling around for some. Let me know where to locate a set. Thank You. :mad: | | |
#62073 06/23/2006 10:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve been on the waiting list almost a year. I,m just going ahead & putting a T-5 o,drive in instead. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#62074 06/24/2006 2:49 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Patrick's has them, and I beleive that Classic Parts (formerly Chevy Duty) has them also. The gears themselves are manufactured by Richmond Gear, but I don't think they sell them to the general public, only through a parts house like Patrick's etc.
Bill Burmeister | | |
#62075 06/24/2006 3:06 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Patricks and various other places advertise them, nobody actually has them currently, unless you find someplace like this - they did have some old stock on the shelf some months back Bill | | |
#62076 06/24/2006 4:38 AM | Joined: Jun 2005 Posts: 38 Member | | Member Joined: Jun 2005 Posts: 38 | Crap! I need to get this set up myself. What other options are out there if you want to keep your three on the tree? | | |
#62077 06/24/2006 4:50 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's other rear ends that can be swapped, if you can handle 5 lug, or you can wait and hope that Richmond Gear makes another run before our trucks all rust away,,,,, again I'm gonna use an original OD 3spd, which do show up from time to time, like on e-bay Bill | | |
#62078 06/24/2006 2:47 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | If you use a 3speed OD you should go to a 3.90 rear end that will give you a final drive in OD of about 2.73 which is perfict for highway driving and are more readily available. Tom | | |
#62079 06/25/2006 2:55 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You can find the 3 speed od for around $100-150 at a swap meet. Passenger and truck units are the same other than the shifter arms and the speedometer drive gear, the passenger unitsm are usually set up for a 4.10 differential.
#62080 06/25/2006 5:32 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually with an OD in the truck, the factory rear gears were 4:11 too
Bill | | |
#62081 06/25/2006 11:27 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you go the OD route, it is the easiest and cheapest, but be sure to checkout the solenoid or get assurance that it works. The solenoids bring more by themselves than the original OD trans purchase. No need to change the rear end because a 4.11 gives a 2.88 final when in OD.
Evan
#62082 06/25/2006 5:48 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I guess what I really meant that the od tranny has a speedo drive gear for the 4.11, which will make the speedo off when you use it with a 3.90 rearend. Also, the '55 manual only shows a 3.90 gear for '55, but I think that 4.11 would be used on the later trucks when that option was availible.
#62083 06/26/2006 2:56 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I've been waiting for a year too. Randy's Ring and Pinion (this is where Patrick gets his) told me they are scheduled for a July production run. That is true encouragements since they didn't even have a schedule until recently.
Mike Barnes 1950 GMC 1-ton pickup
#62084 06/26/2006 9:03 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I was wrong that Patrick buys from Randy's Ring and Pinion. I talked to Patrick this morning and found that Randy's is actually buying from Patrick. Patrick said he will have them on 15 July (finally!).
#62085 06/28/2006 12:53 AM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Hey, are they sure they are going to have them, or were they giving you the same old story. I would sure like a set myself. | | |
#62086 06/28/2006 6:03 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | maybe if you all emailed patrick at the same time,they would realize how big the market for these are. | | |
#62087 06/28/2006 2:23 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I don't think Patrick is a liar but nothing material is truly certain until in hand. Since Patrick is the sole "supplier" of 3.38 gears in today's world where are your options but to wait?
He knows the demand and wants them worse than we do since he puts food on his table by supplying us with parts for our toys.
He previously counted on others to supply them but he has taken over and having them made personally. He received prototypes which were fully tested and approved. The order was placed for production quantities which his manufacturer has committed to ship so they will be on Patrick's shelf on 15 July.
#62088 06/28/2006 7:26 PM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Thanks for the info! hope we get some. | | |
#62089 06/28/2006 7:50 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | You have a beautiful truck. How far is Andover from Springfield?
#62090 06/28/2006 11:15 PM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | About 2 hours. We are up by the Quad cities. Ever been to the cruise in Monmouth IL in August? It would probably be worth the trip. Lots of cruisers. Last year close to a Thousand. | | |
#62091 06/29/2006 4:35 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | No but it sounds real good. Please post the event on the site when you have details. I'd like to inspect your truck and share info on our 3.38 swaps. I sure hope nothing happens to spoil Patrick's schedule cause I'm ready to get it done!
#62092 06/30/2006 2:46 AM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Cruise is August 4th, 6-10 downtown Monmouth IL. We got there last year about 4. It is awesome! No Charge, and al lot of cars and trucks! I can't seem to find out anything else. Everyone in Central IL Come! It is worth the trip. | | |
#62093 07/03/2006 10:19 PM | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Hi y'all. I was just wondering what those 3.38's go for? I'm thinkin about throwin a 55 rear in my 51. Thanks. | | |
#62094 07/03/2006 11:17 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Last time they were available they were about $400. Than you should buy the install kit for another $125. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#62095 07/07/2006 2:20 PM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Hey guys. Talked to Patricks yesterday and they did confirm to me also they are getting some in!
If you want some get on the list! Never know how many they will make. Hope they really do come in. It would be nice to keep up on the highway. | | |
