5 members (Otto Skorzeny, 2-Ton, TexasJim50, MickeyP, MRMEROTH11), 117 guests, and 3 robots.
Topics128,132
Posts1,056,383
Members48,441
Y
Y Offline
I installed a 69 Nova on my 53 3100. Only regret, almost to "low". I like the rear steer, easy to connect. Still has drum brakes and manual steering. One mistake I made was adding 1" to the wheelbase, caused clearance problem with tires. Anybody else have a "subframe" they would recommend?
Threw an Eldorodo front clip in a 73 C-10 years ago. The front wheel burn-outs raised some eyebrows. Also did a 69 Nova (like yours drum and powerless) sub into a 40 FURD. I like it. Real easy to do engine, brakes, and steering. Plus I don't feel like I'm gonna die anymore, but I had to play with wheels to get fender clearance.
I used a 1979 camaro frame on my 54 1/2 ton panel,worked out well no real problems.
layback
74 Nova under a 48 Fleetmaster. Still building the car though,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
why a sub frame clip and not simply a crossmember?
Y
Y Offline
Hey Scott, I had all the materials on hand, and figured I could learn some fabrication skills. I have more skill than $. In my initial post I was trying to find out what other "subframe" would be a good doner. The camaros, novas and monte carlos are getting hard to find, especially if they have disc's. According to my math a crossmember will still top $1500? If I can't come up with a subframe I'll go the crossmember route. Thanks,
Hey all- I put a '73 Nova sub under a '54 Chevy Panel, a '79 Camaro sub under a '49 Chevy pick up, a '80 Camaro sub under a '40 Pontiac 2dr sedan , all with PS and Power disc brakes. And a MII IFS under a '51 Chevy Bel Aire. I like the ride of the subframe better than the MII IFS.
IF you use used parts, the crossmember will cost you under $800 including shipping, paint, weld wire, etc. New parts under $1200.
Plus, you dont have to worry about a weld cracking at a butt joint.
I put a 69 Nova under a 49 Suburban. I bought the clip at a swap meet for $ 200. I completely rebuilt it with new bushings, disc turned, new calipers, etc for $175, did all the mock up work myself, and had a certified welder put it in for $50 and a case of beer I helped drink. I then was able to use standard GM motor mounts and not have to fab up anything. I will say the MKII is a "cleaner" look but subframe is a viable option no one ever thinks of. Little more work but if done correctly I think the cheapest way to go.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
USED A 79 CAMARO ON A 51,3100.ONLY PROBLEM WAS TIME FOR FRONT ALIMENT.NAPA HAS UPPER CONTROL ARMS THAT SOLVED THE PROBLEM FOR CASTER7 camber for 75 bucks.one thing when you put the cilp on take it too a frontend aliment shop.once things are welded you may have to get the front frame twicked.frame bent. this is importent.the front fender and hood to fit right.I wish you luck the story never end's.good luck an do it right the first time.saves a lot of heart breaks & $$$$$$ gallery dan-pa 51 chevy
dan-pa
V
Ven Offline
Apprentice
Apprentice
V Offline
Bag it up front and get some lift out of it. Lay it out when its parked!
¿ÐíÐ Ï Hí‡ †hŇ?
