| | | Forums66 Topics128,032 Posts1,055,519 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62056 06/23/2006 12:46 AM | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Hi All, I have been looking for a suitable rearend for my 54 panel. It's auto with a 350. I found a 70's something Nova with auto and a 350. The inside flange to flange measurement is 53" which will put the outside dimension at around 60". From the charts I have my 54 was originally 62" flange to flange. Do you guys think this Nova will be too short? Thanks.
All the best, Ted
#62057 06/23/2006 2:16 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have a 79 nova in my 54 3100 and have had for 20 yrs. when i had 235/70/15 tires i had a slight rub on the inside when i went around corners. i put a spacer and longer studs. check tire width for clearance and you will be ok. Ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#62058 06/23/2006 4:29 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | 68-79 Novas have the same sized rear ends. The 62-67 are the only ones that are smaller. Check here: http://www.novaresource.org/axle.htm This guy (Scott Windle) really knwos his Nova stuff. | | |
#62059 06/23/2006 4:59 AM | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Thank you Ron, now I know it can be done with consideration to tire size.
Thank you Ray, incredible information at the nova site. It will be great fun finding out what I am getting.
You guys are great.
All the best, Ted
