3 members (Charles in CA, Hotrod Lincoln, 1 invisible), 117 guests, and 1 robot.
Topics128,151
Posts1,056,994
Members48,460
Hi, I just bought and am fixing a 1942 Chevy 3/4ton. I want to keep the original motor tranny and rearend. It has the original 216 and 4 speed tranny. Is there anything i can do to get better cruising speeds with the original drivetrain?
Taller tires. Jet engine in the bed.
He's kidding, but he's right. To increase vehicle speed or reduce engine speed, one of those has to change significantly:
O/D added to existing transmission (Gear Vendor, etc., $$$).
New O/D transmission (T5).
Lower numerical axle (3.55 instead of 4.11).
At least 2" taller tires.
Where or what kind of vehicle does a t5 tranny come out of?
I'm not sure I was kidding. If you are not willing to change the motor, trans and rear you have very limited options to increase your speed.
Another helpful thought would be to always drive downhill.
The T-5 transmission was available in Jeep Cherokees, S-10 pickups and Camaros and Firebirds. And Mustangs and Astro vans.
How do you plan to use this truck? Some description of your plans and intended usage might better match the suggestions you get to how you'll use the truck.
What kind of drive line does your '42 have?? Does it have 6 or 8 bolt wheels?
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
It has a 216 and the original 4 speed tranny with 8 bolt rims.
I went with a set of 4:11 gears in my 53 3/4 ton, not sure if that swaps back to the '42 or not. This was a bolt-in deal, lots of sweat but it all bolted up and now I can cruise at 'near' highway speed, ok not interstate speed but without a line of cars with horns blaring. Found the gears with a wanted ad here on the Stovebolt site, from a late 60s 3/4, 4:11s are a huge improvement over the 4:56s.
Best of luck.
Jim
1946 1/2-Ton Chevy
Your 42 3/4 ton may not be a 42 3/4 ton. A 42 3/4 ton would have 6 lug wheels, just like the 1/2 ton. Maybe post some numbers so we can identify what you have. 1946 was the first year for 8 lug rims on a 3/4 ton.
4.11/4.56 = 11% faster.
60 becomes 66.5, etc.
There is no free lunch with axle ratios.
There is no magic "high speed + best power", those are opposing goals.
The engine RPM reduction in high gear is exactly the same as the torque reduction in every gear. 4.11/4.56 (and every other swap) reduces both RPM and torque by the same amount: divide new by old, in this case it's about 10%.
The exceptions:
1. wider transmission ratios
2. more gears (4 instead of 3)
3. overdrive
