3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#62012 06/22/2006 6:44 AM
Just thought you'd like to know that a 12" clutch will fit an 11" pressure plate pattern.The bolt holes are the same. If you're running a big bolt and you work it hard,the extra big clutch might be helpful. I priced one today for my GMC,and the 12 inch diaphragm clutch kit was about 160.00,where the 11 inch diaphragm kit was a whisker over 200.00;not a bad deal. This was for a LUK brand clutch,through Britestar Sales here in Elko.
I had one of their 10.4" clutches in the GMC behind the Pontiac 400,and it seemed like a good product.Didn't use the release bearing from the kit though,because
A:it looked cheap-plastic hub,etc.,and
B:I'd just installed a new heavy duty one a half a year before and it was still in great shape.
Now that I think about it though,the plastic hub should work even better than a metal one,because it would be less likely to get crossed up and jam,so next time I'll give it a go.The clutch worked well,and showed virtually no wear,despite some pretty brutal use,towing the 5th wheel and pulling a dead school bus up a ramp onto a flatbed trailer at the end of a long cable.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#62013 06/22/2006 10:51 PM
Riding in the Passing Lane
That,s a good idea if you are working it hard, but its not for everything. It makes slower shifting & is hard on syncros. You wouldn,t want to use it with a small trans. Luk is one of the best brands of clutches. They make most of the OEM.
1972 Chevy c10 Cheyenne Super
#62014 06/23/2006 6:21 AM
which bellhousing is it in? I thought there might be clearence issues. I always used an 11 inch in my 59 gmc 1/2 ton
