| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I want to build a stand to put my cab on so I can work on it and have it off of the frame so I can work on it. Does anyone have any ideas on this? | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | In the tech tips section- http://www.stovebolt.com/techtips/ under general bodywork there are 3 writeups on just how to do what you want. Chuck | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I KNEW I'd seen one somewhere before! There's just so much information on here and other sites I couldn't remember where I'd seen it! Thanks! | | | | | Joined: May 2009 Posts: 8 New Guy | | New Guy Joined: May 2009 Posts: 8 | I'f you don't need to move it......http://img230.imageshack.us/img230/6200/82509032.jpg | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Just a note - if you're going to be doing work such as replacing body panels, leaving it on the frame is best, as you can make sure things line up correctly. It's easier to adjust when it's on the frame before you weld, as opposed to welding off the frame and then trying to make adjustments once you put it back on the frame. If you're not doing any panel replacement then it doesn't matter. Samantha | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | i went to a boat storage place and picked up a jet ski trailer for 75.00 and put a wood bed on it and it works great. i can easily move the cab around in my garage and i use it to take it to the body shop. Paul | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Never thought of that. I think I'll see what I can find around here. | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I want to paint the frame before hand though I suppose it could wait. Plus, I have the 55 cab on the frame and the 58 cab sitting in the floor. I intend to use both cabs to make one. I guess I could remove the pieces I need then place the 58 cab on the frame. | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I like the rotating cab stand. | | | | | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | I've thought about building a rotating stand similar to this for some time. Great pictures it looks like a good design. How hard was it to rotate the cab with it in place? Mongo | | | | | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | Another good rotating stand that I was impressed with that would be mighty handy is one built by kiwiwilly for his COE cab. A couple pics Here and Here. Be great to design one that would work both ways and rotate on both axis'. Mongo | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | how heavy is a raw cab?(47-53)i'm thinking of building some heavy duty sawhorse style stands out of lumber? | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Incorporating appliance casters into a cab stand sure helped me with maneuverability. I used an old futon frame but something can be made out of a couple pallets in a pinch. IMO it takes 4 guys to lift it safely.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I've tried with two people and you have to plan a spot for the cab to land when you drop it! Actually, two can do it but only for short distances. | | |
