| | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I have a 49 burb and am researching what to do with the rear floor. The plywood is solid but top covering is shot. I have seen threads on trying to get new material made etc. but not going that direction, My question is how close is a 1/2 ton truck bed to the rear profile of a suburban? Would a Mar-K type bed kit come to close fitting with minor modifications?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The fender wells "cut into" the Suburban rear floor. The fender wells are completely outside the pickup box/bed.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 49bourbon: my floor is very solid to but the top "ply" is a little bad in places due to dragging stuff in and out of it as it was a delivery Panel. I'm seriously thinking about just putting a nice 1/4" sheet over the top of it.... or fill the places and sand down real good for some type flooring/carpet or something like that. Keep us posted on what you do. I think my wood is solid from all the road salt up in the midwest west...it preserved the wood but killed the sheetmetal  | | | | | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | I use my old panel to haul things,and the one I am redoing now I intend to use 2 sheets of marine plywood and split them so to get the width needed and put down wear strips to cover the seam. Should work fine,because as stated the pickup has a totaly different bed makeup.If you used the plywood you could cover it with anything desired.
Dennis M
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | thanks guys I was thinking the nice stained wood kit with painted steel or stainless runners would dress up the rear. I'll find a buddy with a 1/2 ton and make a quick paper template to see how close they are. I'm a long way from this being at the top of the "to do" lists.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Will you be mounting original seats in the rear? If "yes", you'll have to carefully consider the locations of the floor-pockets for the attachment of seats.
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | thanks guys I was thinking the nice stained wood kit with painted steel or stainless runners would dress up the rear. I'll find a buddy with a 1/2 ton and make a quick paper template to see how close they are. I'm a long way from this being at the top of the "to do" lists. If you go this way, take a router and mill away half the thickness of the plywood sheet, about an inch from the center on each half of the floor, and make an overlapping joint. Some wood glue along the whole seem and clamped well will keep the water from seeping through, and it'll eliminate a weak spot in the center of the floor. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | Weeds on here did a really good tech write up on replacing the wood in his suburban using marine plywood. You should check it out | | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | I was planning on using a rubber mat style bed liner in mine for hauling. They look pretty similar to the original. A long box size should get you there, check it out. Bongo | | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | I like the splitting the plywood idea. A lap joint is perfect for this application. I would go one further and say use an epoxy lacquer after it was in and then add the strips. It'd look like a bowling alley. Then to top it all off I'd undercoat the bottom and edges of the plywood. Sorry furniture maker by trade.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Here's the LINK to Weed's great suburban build | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Weeds & George,
It does not get much better than that.
| | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | Very nice Weeds! Picture of perfection. Hope I can Make mine look that good. | | |
