6 members (Otto Skorzeny, Jay R, Eisenholtz, Shardean, Gdads51, rick46ia), 93 guests, and 2 robots.
Topics128,023
Posts1,055,366
Members48,420
#61857 06/17/2006 7:38 PM
Ok..Ok..I have a guy interested in my 50..anyway i haven't had it running since january,,The crazy thing won't start..tried pouring gas down carb,,Nothing,,I used to know what was wrong with these trucks..But i think my brain has gotten rusty..lol..anyway..I know someone will give me advice on here..I sure could use it cool ,,thanks in advance-design...lol
#61858 06/17/2006 8:29 PM
What does "Nothing" mean. Crank speed, spark, etc.
#61859 06/17/2006 8:47 PM
Ex Hall Monitor
Ex Hall Monitor
Like Baldy said what is "nothing"? It takes spark, fuel & air. I would first pull the fuel line from the carb & crank it. If there is no fuel it could be a plugged fuel line, bad pump or no gas in the tank. If there is fuel to the carb pull a plug wire & crank it with the ignition on, holding the end of the wire against a ground. No spark check the ignition components. If you get a spark it could be a plugged air filter but that's unlikely. I would then go back to the fuel system, pull the top off of the carb & make sure the gas you're getting to the carb is going through the carb. If it's been sitting that long there's a good chance you have a varnished carb & need a kit.
#61860 06/17/2006 8:48 PM
The first thing I do is go to the auto parts store and buy a can of engine starting fluid. Spray it ,choke it, and sometimes crank it. Need more info like Baldy said.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#61861 06/17/2006 10:49 PM
File the points first, check for spark, then check for fuel. Start with the basics,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#61862 06/17/2006 11:04 PM
While you're filing the points, make sure they're opening and that the rubbing block isn't worn down.
#61863 06/18/2006 5:39 AM
No spark...Coil?//Points??..truck last ran in january..
#61864 06/18/2006 5:55 AM
Check to see that you have power to the coil when the ignition switch is on, then see if the other LT terminal on the coil is switching from v+ to ground when the engine turns over. Then report back.
#61865 06/18/2006 2:57 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
Baldy is taking you in the right direction. I had one thought (does happen on occasion) did you make sure the ignition switch was on when you checked for spark? That sounds dumb but it's not uncommon. Also, check for spark in a darkened condition. A spark is a lot easier to see in the dark. If you truly have no spark it's uncommon for a coil to go bad just sitting but it can happen. I would look at the points & condenser too.
#61866 06/18/2006 4:51 PM
Quote
This is exactly what I had to replace when I let my 49 sit to long between cranking it up (about 5 years ago). While I was at it, I also changed the plug wires, plugs,cap, rotor, and ballast resistor. But Baldy and the others might put you on a more simplified fix. Like check all your connections for corrosion or mouse bites.
#61867 06/20/2006 12:44 PM
50chev,
Did you ever get it cranked & running? I wished I had known about The Stovebolt Page 5 years ago before I replaced EVEYTHING to get mine running. These guys & gals are super at trouble shooting!
