7 members (Otto Skorzeny, Samantha, MNSmith, Phak1, cmayna, CATMAN, Gray_Ghost), 62 guests, and 1 robot.
Topics128,154
Posts1,056,850
Members48,456
Are the rear fenders on the 55-66 stepsides the same? If so, would the fender mounted tire carriers be the same for the short beds 55-66. I know there was a difference for shortbed/longbed, but the beds are pretty much identicle.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Not sure exactly what your question is. Are you interested only in the spare tire bracket for a shortbed with the spare tire fender cutout?
According to the people that sell them the stepside fenders themselves are the same from late 54 to 66. Not sure if it's what you're stating above, but the left rear fender with the spare tire cutout is different between the long and short beds. The long bed mounts the tire lower. I don't have a side mount spare so no first hand experience with the brackets. Hopefully someone that has one will chime in.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Yeah, thats my question. Sorry...want to know what years fenders/carrier I can put on my 63 shortbed stepside.
yes and yes to your original questions
No, the fenders are different long bed vs. shortbed IF they have a spare tire cut-out. And I have pictures to prove it. thumbs_up
Let me expand on Markeb01's comments.
The long bed fender mounts the spare tire lower. In addition it mounts it closer to the cab.
The short bed fender mounts the spare tire higher. In addition it mounts it farther away from the cab.
I used a long bed fender on my short bed cause I liked the lower tire look. However you are limited in the size of the spare tire you can mount with this set-up.
Check out this link and go to post #7 for some comparison photos and additional data: http://67-72chevytrucks.com/vboard/showthread.php?t=363509
I hope this helps
Thanks for the help. I have a short bed and am searching for the fender and bracket now. Just wasn't sure what years I could use. I realize there is a difference in the short/long bed
