3 members (1955 1 Series, Otto Skorzeny, Gdads51), 51 guests, and 1 robot.
Topics128,037
Posts1,055,580
#617766 02/07/2010 11:06 PM
can i use the original v8 throttle linkage to convert my straight 6 throttle linkage to fit my new chevy 350 im installing in my 1959 gmc pickup
yo
not clear what you have, but there's a difference between V8 and 6 linkage - for the V8 the necessary piece is this [available at vendors], mounts on the firewall and connects the pedal to the throttle rod on the engine
Is that a the same linkage used on a 1959 v8 engine originally or is it an after market item
yo
it's an exact reproduction [any repro item is "aftermarket"] of the linkage used on all 55-59 V8s, bolts to the existing holes in the firewall, hooks to the existing pedal - as shown in the assembly manual
k thanks for your help
yo
The linkage in the picture is a reproduction, but not exact. The mounting area is curved on the firewall so the bracket has to be modified in order to work. There are no holes in the firewall for the V-8 linkage if the vehicle originally had a 6 cyl.
Fred
the correct holes for the linkage is on all 58 and 59 [at least] firewalls, 6 or 8, don't recall about the 5-7, all those years I've had I left as 6's, but as the V8 was started in 55 with that linkage, I'd expect to find the mount holes .... and the repro linkage bolted right up to my 58 in pic above
