Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Rnl364, baldeagle), 56 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
#617301 02/06/2010 1:39 PM
Finished my last project; dug out the next one and started in; 1928 Chevy literally in pieces. Three days in, and LOTS of hours. First problem: won't bore you with details, but need a donor frame and found a rolling chassis from a 1950 pickup. It would give me modern brakes, suspension, steering etc. It is the answer. Question: I found the dimensions of a 1950 pickup online and it showed 46 inch width on the frame rails "at the rear" which is not where I need a measurement right now before I pay the money for the rolling chassis (150 miles away so measuring it is not an option right now). Can anybody tell me or direct me to a link where the approximate width is of the frame where the cab would be placed, of a 1950 half ton is located, so I can see if my 1928 cab will be "close" to working on it.
professor229 #617347 02/06/2010 4:43 PM
3B Offline
Hy professor229, I couldn't find a dimension chart that showed the different width dimensions, but the frame is 173 1/8" long, 47" wide at the rear, and 29 1/4" wide at the front, the frame rails are straight, maybe you can extrapilate the dimension you require by making up a wood model, hope that helps.
3B #617397 02/06/2010 7:24 PM
where the front cab mounting holes are, the frame is 32 inches wide and at the rear cab mount the frame is 37 1/4 inches wide.
Just my thought, but the AD frame is much too wide for a 28 Chevy.
I've got a 28 Chevy car, and a couple AD trucks (but not a 1/2 ton) and my first guess is that's going to be a tough swap if it even works.
The 28 is a very narrow car, and the AD trucks while still narrow is somewhat wider than the 28.
Best do some careful measuring and figuring before deciding for sure.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #617533 02/07/2010 4:02 AM
The 3/4 tons are 11" more narrow at the rear, front in is the same as 1/2 ton. Hope this helps.
~Jim
BIG CHEVY 3600 #636791 04/12/2010 12:25 AM
2 Offline
Professor I have a 28 chevy and am in need of a battery box. Do you have 1 in your frame and can you take dimentions and some photos so I can make 1.
