| | | Forums66 Topics128,035 Posts1,055,556 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 38 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 38 | Finished my last project; dug out the next one and started in; 1928 Chevy literally in pieces. Three days in, and LOTS of hours. First problem: won't bore you with details, but need a donor frame and found a rolling chassis from a 1950 pickup. It would give me modern brakes, suspension, steering etc. It is the answer. Question: I found the dimensions of a 1950 pickup online and it showed 46 inch width on the frame rails "at the rear" which is not where I need a measurement right now before I pay the money for the rolling chassis (150 miles away so measuring it is not an option right now). Can anybody tell me or direct me to a link where the approximate width is of the frame where the cab would be placed, of a 1950 half ton is located, so I can see if my 1928 cab will be "close" to working on it. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy professor229, I couldn't find a dimension chart that showed the different width dimensions, but the frame is 173 1/8" long, 47" wide at the rear, and 29 1/4" wide at the front, the frame rails are straight, maybe you can extrapilate the dimension you require by making up a wood model, hope that helps. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | where the front cab mounting holes are, the frame is 32 inches wide and at the rear cab mount the frame is 37 1/4 inches wide.
Just my thought, but the AD frame is much too wide for a 28 Chevy. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've got a 28 Chevy car, and a couple AD trucks (but not a 1/2 ton) and my first guess is that's going to be a tough swap if it even works. The 28 is a very narrow car, and the AD trucks while still narrow is somewhat wider than the 28.
Best do some careful measuring and figuring before deciding for sure.
Grigg | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The 3/4 tons are 11" more narrow at the rear, front in is the same as 1/2 ton. Hope this helps.
~Jim
| | | | | Joined: Apr 2010 Posts: 1 New Guy | | New Guy Joined: Apr 2010 Posts: 1 | Professor I have a 28 chevy and am in need of a battery box. Do you have 1 in your frame and can you take dimentions and some photos so I can make 1. | | |
