7 members (Steve L., WICruiser, Bill Hanlon, Bucker, Peggy M, Hotrod Lincoln, klhansen), 68 guests, and 2 robots.
Topics128,206
Posts1,057,435
Members48,471
looking for ideas on what to do with it. not sure if i should get a bigger engine.It was in storage for 7 years and not sure what i should replace ..thanks
Joy Offline
Welcome to Stovebolt. We are glad you joined and if you go to a few of the different forums on engines or just truck talk, they will give you their opinion on what they think. Good luck and have fun!
Welcome to the Bolt Jonny5. YOur at the right place!!
Hey, whats wrong with getting it running and drive it like it is while you decide just what it is that you want to do. You already have 12 volt and the engine compartment can handle about anything so now is time to think. I personally like a little more horse than the 6 cyl. but I can also see keeping a nice truck in original shape.
Some pics may help out when you can post some and Joy gives some good advice about posting in the best forum for the most views and comments.
Good luck.
Clean out the tank!! My 65 step had been stored for 22 years and while driveing it north (300 miles) it started running rough. Took the top off the carb and was amazed at the crap inside. I have since rebuilt the carb and will clean the tank out after I get it home. I plan on keeping the 6 in place adding split manifolds with dual exhaust and not sure where I will go with the carb. I like the look of dual carbs but hear a 4 barrel 390 cfm carb on Clifford manifold works really good.
1955 Chevy 3100
engine has a slight tapping when idling ..valves?
Ditto on cleaning the gas tank. After 7 years of storage, if you're not having problems yet, you will soon.
The tapping noise could be valve lifters. Give it an oil change, and it might come out of it after you run it a bit. Also, if there's varnish in that gas tank, running that into the engine can make all kinds of things stick! Don't ask me how I know that!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
JONNY5, Welcome, I am interested in seeing your progress as I have acquired a '65 myself with a 292 in it, 4 on the floor. These trucks are a lot of fun if you keep it that way. I used to have a '61 C20 when I joined this site, been deployed a lot (Navy) and learned a lot from the forums. The search option is very helpful and if I still can't find an answer, then I post my questions. Happy surfing and again...welcome. -Will Hammond
"Remember Who You Are And What You Represent"
"Being responsible sometimes means [censored] people off"
- General Colin Powell
