7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
34
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | I have a new sending unit in my gas tank,but,the gauge is off.Can i readjust the float unit in the tank,or is there another way.Sorry,forgot to mention that when i fill it up,the gauge shows just less then 3/4 tank.
Roy | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Yes you can take the unit out of the tank on mine I had to set the hgt. of the unit in the tank so it was 3/8 of an inch higher than center and cut the arm so it was a little shorter that is what the instructions told me to do than I moved the arm up and down and looked at the gauge to make sure it was reading right.
Pete
| | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Pete,thanks for the input. Gonna see if i can get in the garage this weekend.
Roy | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Shortening the float rod will make it read fuller (more full???) on a full tank.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I am have issues with my gauge, too. When the tank is full it only reads half (empty or full?).
Pete52. What did yours read and what did you do?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | oldblue - just bend the float arm up a bit until it reads full - then drive it until it runs out and see where empty reads
Bill | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If you shorten up the rod it will be able to move in the tank better in both directions so that it will read full and empty I shortened mine to 8 1/4 inches but the way you do that is take the sender out of the tank and as your watching the fuel gauge lift the float until the gauge reads full if the float is above the top of the sender you will have to shorten the rod so the float is just below the top of the sender as it would be in the tank when you have a full tank than it should also read empty when you lower the float to the same depth of the tank if your tank is 18 inchs deep than when your float is at 18 inchs it should read empty check both ways before cutting your float rod I had to adjust my sender so it was 3/8s of an inch higher than the center of the tank.Now my gauge reads full and empty so i don't have to quess.
Pete | | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Thanks for the info pete.Gonna see if wifey will let me play with my truck tommorrow.Will let you guys know how i make out.
Roy | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | No Tiny it will not make it read more fuller but the under frame tank I installed in My truck was only 8 1/2 inches deep so I had to shorten the float rod to give the rod more room to move up and down in the space I had,If the tank would have been 12 or 14 inches deep The rod would have been longer to read right so now it reads full when full and empty when empty.
Pete | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | No Tiny it will not make it read more fuller....
Pete Yes it will. Think about it. If the rod is so long that it reaches the top of the tank before it reaches the top of it's travel. It won't read full. With the shorter rod it will reach the top of it's travel and show full. That is exactly what I had to do with my 38 to make it read correctly when I had a universal sending unit in it. I believe you said the same thing in your previous post.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thats what I wanted One ear dicky to understand you can "adjust" the float to read right kinda like every thing else we have to do on these trucks .
Pete | | |
