1 members (1 invisible), 56 guests, and 6 robots.
Topics128,014
Posts1,055,324
Members48,419
#615885 02/02/2010 2:27 AM
I have a new sending unit in my gas tank,but,the gauge is off.Can i readjust the float unit in the tank,or is there another way.Sorry,forgot to mention that when i fill it up,the gauge shows just less then 3/4 tank.
Roy
Yes you can take the unit out of the tank on mine I had to set the hgt. of the unit in the tank so it was 3/8 of an inch higher than center and cut the arm so it was a little shorter that is what the instructions told me to do than I moved the arm up and down and looked at the gauge to make sure it was reading right.
Pete
Pete52 #616209 02/03/2010 1:27 AM
Pete,thanks for the input. Gonna see if i can get in the garage this weekend.
Roy
Ex Hall Monitor
Ex Hall Monitor
Shortening the float rod will make it read fuller (more full???) on a full tank.
Tiny #616423 02/03/2010 3:49 PM
I am have issues with my gauge, too. When the tank is full it only reads half (empty or full?).
Pete52. What did yours read and what did you do?
Dennis
oldblue - just bend the float arm up a bit until it reads full - then drive it until it runs out and see where empty reads
squeeze #616847 02/04/2010 9:50 PM
If you shorten up the rod it will be able to move in the tank better in both directions so that it will read full and empty I shortened mine to 8 1/4 inches but the way you do that is take the sender out of the tank and as your watching the fuel gauge lift the float until the gauge reads full if the float is above the top of the sender you will have to shorten the rod so the float is just below the top of the sender as it would be in the tank when you have a full tank than it should also read empty when you lower the float to the same depth of the tank if your tank is 18 inchs deep than when your float is at 18 inchs it should read empty check both ways before cutting your float rod I had to adjust my sender so it was 3/8s of an inch higher than the center of the tank.Now my gauge reads full and empty so i don't have to quess.
Pete
Pete52 #617253 02/06/2010 6:11 AM
Thanks for the info pete.Gonna see if wifey will let me play with my truck tommorrow.Will let you guys know how i make out.
Roy
One ear dicky #617454 02/06/2010 11:25 PM
No Tiny it will not make it read more fuller but the under frame tank I installed in My truck was only 8 1/2 inches deep so I had to shorten the float rod to give the rod more room to move up and down in the space I had,If the tank would have been 12 or 14 inches deep The rod would have been longer to read right so now it reads full when full and empty when empty.
Pete
Pete52 #617459 02/06/2010 11:46 PM
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by Pete52
No Tiny it will not make it read more fuller....
Pete
Yes it will. Think about it. If the rod is so long that it reaches the top of the tank before it reaches the top of it's travel. It won't read full. With the shorter rod it will reach the top of it's travel and show full. That is exactly what I had to do with my 38 to make it read correctly when I had a universal sending unit in it. I believe you said the same thing in your previous post.
Tiny #617552 02/07/2010 4:56 AM
Thats what I wanted One ear dicky to understand you can "adjust" the float to read right kinda like every thing else we have to do on these trucks .
Pete
