1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#6164 03/30/2005 6:33 AM
Junior Member
Junior Member
Here we go. I need information about water pumps, pulleys and fans used on the 216 and 235 chevy engines. Which fans go with which pulleys and on what size of engine?
I have a 1950 Chevy Pickup with a 1956 235 engine. I know I need the short shaft water pump, but I don't know what size pulley or fan. I have seen them in almost every combination. (Probably not a good thing). I have also heard the term cavitate or cavitation...I need to be straightened out on the subject.
If someone could explain all this to me that would be awesome.
#6165 03/31/2005 3:05 AM
I just went through that. I used the 3" pulley first and my engine would not cool. I switched to a 5" and got it cooling. The original for the '56 engine was 6" so if you could find one that size it would probably be better. (All sizes are approximate.)
Here's a link to the discussion we had.
#6166 03/31/2005 10:46 PM
You can get a low dish 7" pulley off a Ford truck in a junkyard which is the perfect size for the stock water pump, just with less dish. Then you use a press to shorten the shaft. However, this leaves the water pump low on the block and the stock fan might hit the harmonic balancer. You can either go electric, or get a fan that fits.
However, the best option is to get an adaptor plate that lets you run the 216 pump on the 235, which puts it up high where it belongs.
Paint & Body Shop moderator
#6167 04/06/2005 4:32 AM
Junior Member
Junior Member
Thanks from your help,
I will give it a shot
#6168 04/06/2005 12:19 PM
I just went through this same situation. I have a 55' 235 and a 53' pick up so identical problem. I relocated the radiator flanges to the rear of the radaitor so it was moved all the way forward in the surround. Got a short pump and pulley from Patricks and then went through about 4 fans and spacer setups before I got the clearance on the crank by tweaking the blade from a 56' Chevy car. It just does clear and looks like it should work. There may be a better setup but this is what I did.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#6169 04/06/2005 9:35 PM
Junior Member
Junior Member
Here is a deep question
Instead of buying the special water pump from Patrick's, I bought one from Car Quest, pressed the mounting plate down and cut the shaft. It fits great.
When I look in the radiator, it doesn't seem like the coolant is moving like it should. My thermostat (180) works, and it was hot when I checked it.
I am wondering if the impellers could be different on these two different pumps. The "right" one from Patrick's, or mine from Car Quest.
I have the 6" pulley
#6170 04/07/2005 4:44 AM
What do you think, Patrick grows them? I don't know what he charges but I'll bet he makes a healthy profit doing the same thing you did.
#6171 04/07/2005 5:02 AM
smile
I might be wrong in making this remark, but I don't think you will see a whole lot of movement when looking into the opening of a full radiator.
