0 members (),
104
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | Hi, I tried the search feature with little luck. Maybe better key words....... I have a rebuilt 6 that I know little about. Anyone know the size, type of low-end bearings, Oils to use? Pros or Cons? I'm willing to hear anything about them. I'm not new to flatheads just new to GMC...
| | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | I'm not sure, but I believe that engine is actually an Oldsmobile, used by GMC in some of their trucks that year. Try cross-referencing to Olds engines of similar vintage. Jerry
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Before '38 or '39 GMC used Olds and Pontiac motors. I'm not the one to offer any details of these motors because I don't know them, but if it's a flat head it's definitely not a GMC motor.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The 1936 GMC T-14 used an Oldsmobile 213 cubic inch flat head six cylinder engine. For particulars you might inquire at www.oldgmctrucks.com
| | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | Wow! thanks...... Olds huh. It will be interesting to see if they recammed it, or did any thing else or just jammed a car engine in a 1 1/2 truck. I follow the lead you guys gave me. | | | | | Joined: Mar 2003 Posts: 316 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 316 | Sent you an email with engine specs attached. | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | KC......engine in question will be a PONTIAC being a Flathead. 36 and on grew bigger in cubes upwards of 234's etc. Shared between GMC, Pontiac etc for a few years. | | |
